InQuit OST to PST Converter- Office 365
For the smooth conversion from OST file to Outlook PST file using the best InQuit OST to PST Converter application. Using this program you can convert single as well as multiple files at a one time without consuming more time. With the assistance of this tool, you can access lost and permanently deleted data in a safe manner. Through the help of this setup, you can migrate your data into several file formats such as PST, EML, MSG, HTML, EMLX, vCal, vCard. Apart from its support Office365 & live Exchange Server that is a cloud-based application.
InQuit Best Features:
  • Before the conversion, it shows the preview of recovered mailbox.
  • Give a better result than your expectation.
  • Show the preview of recovered mailbox along with all the data of OST mailbox.
  • Provide 24x7 technical support.
  • Free demo facility that allows you to convert 30 emails per folder free of cost.
  • Serve 30 days money back guarantee.
If you are suffering from some problems regarding how to save your corrupted data. So no need to worried about this software because eSoftTools OST to PST Converter Software brings the latest software to recover your data easily and safely. With OST Recovery Software you can convert ost file into multiple formats: PST, EML, MSG, HTML, EMLX, vCal, vCard.
Read more info about eSoftTools OST Recovery Software
Migrate single as well as multiple files without facing any difficulty by taking the help of Bulk OST to PST Converter application. With the help of this program, the user migrates their data into several interesting file formats such as PST, EML, EMLX, HTML, MBOX, vCard, HTML, vCal, MSG. Before the actual conversion, it shows the preview of recovered mailbox. The integrity of your data after the conversion same as before. A novice user can easily operate it without any technical skills for the conversion of OST to PST file format. It supports OS Windows version such as 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). The user directly migrates their data into cloud-based application Office365 & Live Exchange Server. For further details please visit :-
Convert OST to PST through the help of OST to PST Converter application that is the best way for the conversion task. Using this tool you can access lost and permanently deleted data in a few little moments without facing any difficulty. This tool is known for its good working performance. The user extract single as well as multiple files at a one time without losing any difficulty. Before the actual conversion, it shows the preview of recovered mailbox. It supports PST, EML, EMLX, MBOX, HTML, MSG, vCal, vCard file formats to preserve the data for future use. If you are not satisfied with this program so you can return it within 30 days.
Read More Info:
Convert OST to PST
Export OST file items to Office 365 Cloud by utilizing the best OST to PST Converter software of eSoftTools which simply extract all the database from the offline OST file to many different file formats such as PST, EML, EMLX, MSG, HTML, vCard, MBOX, and VCF. This free Conversion utility allows the user to selectively move the items from the OST mailbox to the newly created PST file without any Outlook installation. This free OST to PST Converter is also capable to restore the OST items like emails, contacts, chats, tasks, notes, journals, and appointments from corrupted, damaged and encrypted OST file to the desired file format. Get a free trial version of this software which can freely convert first 50 items from per folder of the OST file to PST.
Get More Info: Convert OST to Office 365
