Is it safe to use Eraser in safe mode?
tigerbiter
I'm running W2k Pro.
I've thought about running Eraser, for unused space cleanup, in safe mode, in order to speed things up.
It seems that it would be safe, but I don't know.
Is it safe?
I use Eraser 5.7.
spy1
Safe? Yes (at least on an XP Pro system running 5.7).
But faster? No. A lot slower, here. I don't know why, but doing scans in "Safe" mode here - not just with Eraser but with just about every program I've got that "scans" - is horribly slow. (Which doesn't make a whole lot of sense, unless there's a driver that doesn't get started in "Safe" mode that all these programs need).
Sorry I can't be of more help. Pete
Robbie
definately slower in safe mode. My guess is that some things that need to be loaded to speed up things aren't loaded.
A cluster tip wipe in safe mode is recommended every now and then, as fewer files are locked. But for optimum performance / speed I would suggest doing the actual unused space wipe in ordinary mode.
Carver
I've done a freespace wipe in safe mode, it takes 40 hours for my 2x120 gig HDs. If you try it, plan not to use the computer for 2 days.
