Know how to fix Outlook error 0x8004010f
Error code 0x8004010f is one of the frequently occurring error. It is basically a send/receive error which generally occurs while sending or receiving the emails over the Outlook. There are many reasons behind the occurrence of this error such as Outlook profile and OST file corruption, change in Outlook files location etc. It can be fixed by using simple manual methods:
  1. First, locate the Outlook data file.
  2. Create a new profile in MS Outlook.
  3. Now, make this newly created Outlook profile as default Outlook profile.
However, sometimes using manual methods is not that much helpful. You need to repair the PST files as there are chances that the error is appearing because of corruption in PST file. In that scenario, you can use inbox repair tool if there are minor corruptions. However, for severe corruptions, you can use a third party Outlook PST Repair tool.
alex786
To fix all types of Outlook PST file errors without tampering any content, I would recommend you go with Shoviv Outlook PST Repair tool. This tool provides a safe and reliable solution to repair PST files, restore deleted items from PST files and export PST to Office 365, Live Exchange server, new PST, EML, and MSG. Users can also download a free trial version and a good technical support team.
Read More: www.shoviv.com/outlook-pst-repair.html
