Loading Issue
gray123
Hi.
I encrypted my data disk F: with veracrypt. Eraser was loaded to this disk as was ccleaner. Now when I try to re-install to C drive both insisted on trying to write to F disk and aborted even though I specify to load to C drive ( it can't write anything to F: - drive still shows but as as zero bytes under windows and now mounts to separate veracrypt assigned letter L). I manually edited the registry and removed all references to eraser and ccleaner. This worked for ccleaner which then loaded correctly. Eraser still tries to load to F: drive. So are there other things I need to remove from registry under a different label or will eraser try to write something to any disk attached to the computer in which case it can't be loaded on an encrypted drive.
Any ideas,
Cheers gray
garrett01
Administrator
Staff member
Uninstall eraser and then search the registry for eraser - If you installed it to the encrypted drive then the issue is that eraser needs that drive activated to load the com drivers.
