Microsoft EDB to PST Converter
Today's big organizations are moving to exchange database to store the large amount of data. But suddenly some errors came in Microsoft Exchange database makes it inaccessible. But don't worry Enstella Systems made a perfect solution and the name is "EDB to PST Converter" which helps to easily overcome all corruption issues from Exchange database. It authenticate all users to Convert EDB to PST, EML, MSG and HTML format including with subfolders like "inbox, outbox, starred, snoozed, journals, contacts and calendars" etc. EDB to PST Converter never change original structure of EDB data while performing conversion task. It smoothly installs with lower systems requirements and perfectly works with all windows & MS Exchange server versions.
Note: Great opportunity for Exchange users to use EDB to PST Converter at lowest price $99.
Read more: EDB to PST Converter
The conversion process of Exchange EDB file to Outlook PST file format is very easy and secure with the help of EDB to PST Converter application that is equipped with multiple amazing key features without any difficulty. The users save the data into various file formats like PST, EML, EMLX, MSG, vCal, vCard, and MBOX. This application automatically scans all the errors of the EDB file and rubs them instantly without consuming more time.
Read more: https://www.inquitsoftware.com/en/pages/edb-to-pst-converter.html
1191
I suggest you powerful and advanced EDB email conversion software recovering and converting exchange EDB files to PST files. eSoftTools Exchange EDB to PST Converter software can easily convert EDB to PST items including all EDB emails, contacts, task, calendars, reminders, notes, and embedded images etc. The Software works to export EDB to multiple file formats PST, EML, MSG, EMLX and HTML.
Get details of
