MSG to vCard converter
eSoftTools MSG to vCard converter program is one of the best tool to extract the Outlook MSG to vCard VCF, unlimited MSG file can be added for the bulk conversion in VCF format. The converted formats support all accessing like i-phone, smartphone, Outlook express, Lotus notes, Apple mail and etc. This tool is a reliable source to convert the MSG contact without losing the original data structure of the existing file of the user. A preview is shown to all the users to track the proper excel file conversion to the VCF. A FREE TRIAL version is available to all the user by which 5 MSG contacts can be converted efficiently.
Get more info:- https://www.esofttools.com/msg-to-vcard-converter.html
jamesband
You can simply migrate the Outlook MSG data into vCard format by using the MSG to vCard Converter software which gives you the direct conversion solution to move the data from MSG file of any size into vCard (VCF) format. There is no loss data you will see, its a safe mode of data migration and supports all Windows Platforms. To check more info visit here:- https://www.softaken.com/msg-to-vcf-converter
