NSF to PST Converter - Export Lotus Notes
Now Convert the Lotus Notes NSF file data into Outlook PST file data with InQuit NSF to PST Converter Software. This Lotus Notes Converter Tool can export the large sized NSF file into multiple formats like as PST Outlook, EML, MSG, MBOX, EMLX, vCal, vCard, Office 365 and Live Exchange Server with all attachments.
Steps to convert NSF file to PST file-
Select NSF file in InQuit NSF to PST Converter.
Choose the Export file option in PST file formats in desired location.
Click the Convert button and save the NSF file in PST file format.
Read more: InQuit NSF to PST Converter
eSoftTools NSF to PST converter software tool can be helpful to export Lotus Notes into various file formats like PST, EML, EMLX, HTML, MSG etc. It is so easy to operate that even a non-technical user can use it efficiently. Just before finishing the conversion, the user can view recovered mailbox with all its elements in a readable format on their screen. It can support all the version of IBM Lotus Notes latest ones. It can be tried for free in the form of a demo version. If you are not happy with its performance then you have the option to return it within 30 days.
1062
Explore more here:
http://www.esofttools.com/nsf-to-pst-converter.html
NSF to PST Converter software which can easily export IBM Lotus Notes all emails, items, folders, into Outlook PST Format. It provide facility with this tool that converts NSF file into PST or HTML file Format because both of these format are very easily to access and reliable for safety. This Software also enables to migrate NSF contacts separately in CSV file format. Download this application to effortlessly transfer NSF to Outlook PST file with every single data available existing with NSF mailbox.
devin
NSF to PST Converter is an efficient application to Export lotus notes NSF to outlook PST without any annoyance. Separately from that, users can also convert NSF files to MBOX, MSG, EML, EMLX, and PST formats.If you essential a protected answer to convert NSF to PST format. I recommend using Converter because it is safely and efficiently change multiple NSF data into PST format.
More Info :- NSF to PST Converter
If you want to search best NSF to PST converter, go with most trustable software Shoviv Lotus Notes to Outlook converter.
Shoviv Lotus Notes to Outlook converter is another effective solution which provides the best results. It migrates multiple NSF mailboxes to PST Outlook and also exports into EML, MSG, and HTML. It supports all versions of IBM Lotus Notes, Outlook, and Windows OS.
You can download its free trial version and migrate the first 25 items per folder.
More details, visit:-
For conversion of Lotus Notes to Outlook, you can use manual procedure or can use an NSF Converter software tool.
