NSF to PST, Converter
With the assistance of ATS NSF to PST Converter user can convert single as well as multiple files in a few minutes. This application supportable with all the version of Lotus Notes .0.1, 9.0, 8.5, 8.0.2, 7.0, 6.5 and 6.0. With the help of this tool, you can access lost and permanently deleted file along with emails, inbox, outbox, sent-items, deleted-items, drafts, contacts, calendars, notes (to, cc, bcc, subject, date and time). It shows the preview of recovered mailbox before the conversion process. It split large OST file into several small PST file according to users need and restore the data into several file formats like PST, MSG, HTML, EML, CSV, MBOX, vCard, EMLX, vCal.
Read More Info: Migrate NSF to PST
In case if you are hunting for a tool for NSF to PST Conversion at that point pick NSF to PST Converter. It is the outright response to documents. It can recover documents into numerous options like .pst, .html, .txt, .eml, .emlx etc. It can split PST document after recovery into various sizes as indicated by user's decision. It works well with all variants of Lotus Notes server including the most up to date ones.
Download and install free NSF to PST like eSoftTools NSF to PST Converter Software convert NSF files into PST Files. It also allows users to convert and restore NSF files into many different formats apart from PST file like MBOX, MSG, EML and many more formats. it can also split a large file into small files.
Read more info:- eSoftTools NSF to PST Converter Software
Free NSF to PST Converter Software that able for recover the Lotus Notes mailbox items emails, attachment, junk mails, deleted items, contacts, calendar, notes, draft, task and other items and quickly allow users to export the Lotus Notes NSF file into PST, Office 365, MBOX, Live Exchange Server, EML, EMLX, vCal, vCard and MSG file formats without any trouble.
Read more: InQuit NSF to PST Converter
jamesband
For easy Convert your Lotus Notes NSF to Outlook PST file format with the help of NSF to PST Conversion tool to successfully export your all NSF mailbox data like emails, journals, drafts, contacts, permanently deleted emails, notes, attachments, appointments, sent emails, etc. from the PST file format.
More Info :- NSF to PST Conversion
Apart from the above-mentioned NSF to PST converter, Bitdataconversion NSF to PST Converter is another effective solution which helps you to convert multiple NSF files to PST very proficiently. It allows you to export multiple mailboxes into different formats such as EML, EMLX, MSG, and HTML. It supports all versions of Lotus Notes, Outlook, and Windows Operating System. Download its free trial version and check the efficiency of the software. with the help of this trial version, you can migrate the first 25 items per folder.
More details, visit:- NSF to PST converter
Helpful application for Lotus Notes NSF to PST, use this free utility to recover data from NSF file and convert NSF file to PST. SysInspire NSF to PST Converter Software supports all NSF file versions- 9.0, 9.5, 8.0, 8.5, 6.5, and 7.0 to extract emails and other users mailboxes data and also convert them into PST, EML, MSG , MBOX, vCard, HTML, EMLX, CSV and ICS format with emails, contacts, calendars, task, notes, inbox items, outbox items, journals, notes and appointments. Trail demo version of NSF to PST Software that facility to check software functionality and restore 25 emails per folders.
Download here:- https://download.cnet.com/SysInspire-NSF-to-PST-Converter/3000-2369_4-77970319.html
