NTFS - Alternative Datastreams
Hi,
my question is, if the Eraser will overwrite (Erase) alternative NTFS-Datastreams of the files to erase?
Will it?
From the help file:
If you select “Alternate Data Streams”, Eraser will also find and overwrite possible unnamed data streams associated with the file. This option is available only on Windows NT/2000, alternate data streams are supported only on NTFS file system.
