ostconverter
konkaebook
Quickly search Outlook OST file converter software to repair emails & mails items of Offline Outlook OST and also conversion from OST to PST file with all Email properties (like Subject, To, From, CC, BCC, Date, Time). You can convert each database from unlimited size of Exchange Offline OST files to Outlook PST files in a single attempt. Through this application you can restore OST file to PST file and also split restored large PST file into small PST file (1GB to 5GB).
More Details-: OST Converter
To convert multiple Offline Folder Files in Outlook PST and in some other file format you can download OST to PST Converter Software. Software easily repairs as well as convert OST file in various file format including emails, messages, contacts, calendars, appointments and other data items as per user instruction. Software allows user to save OST file in PST, MSG, DBX , EML, MBOX and Archive format after conversion and is available with free demo version for user interface
Puran
you can try Free OST to PST converter to export OST file into PST format. Demo is free for download : convertostpst.org
I am quite late to respond here but I would like to suggest you to use another software named as EmailDoctor OST to PST Converter to convert OST file and repair corrupt OST file. The best thing about this software is that it does not require Outlook or Exchange environment to repair corrupt OST file.
santiano
In this digital world, email plays a very important role. Anyone cannot afford the email to get corrupt or lost. First, try to recover outlook express with email recovery software. If it will not work out then go for email conversion software. Hope the information will useful to you.
Marliza
Hi, OST conversion is done due to several reasons. One among such reason is the OST file is of cached file, not a physical file. Also, if a user needs to transfer their Outlook file to another account then it must be a PST file.
To know how OST to PST happens just hit the link: http://lettoknow.com/ost-to-pst-converter/
Codie
OST to PST converter tool to recover corrupt files very easily and convert OST email into EML, MSG, PST and HTML formats. OST converter is easy way to conversion of OST files into PST files. OST to PST software successfully supported all version of MS Outlook platform.
Also, try free EDB to PST Converter
selvi
Hi
Get the complete recovery of Outlook files in a systematic manner and convert OST to PST format without affecting the original content by using OST to PST Converter Tool. This is completely safe and secure tool in the market.
Thanks
There are multiple options available for converting OST to PST file format, You can google your issue and find best solution. Last time I found a tool for doing same job and found desired result. You can also use that tool for converting ost to pst file format. Download full from here
http://www.ost.topstconverter.com/
Many software are available in the market of data recovery for solving the situation. But still I recommend you the Quick Softknoll OST to PST Converter is the best solution to recover corrupt or inaccessible ost file and convert OST emails to outlook PST, MSG or EML file format. It also displays preview of OST items to let the user verify quality of the recovered mailbox items.The software supports all MS Exchange (including 2016) and MS Outlook (including 2016) versions
Download OST to PST Converter tool and use to recover outlook OST file backup as well as convert OST data into PST file format. The tool work in critical situation also for OST corruption because it has great technique to recover corrupted ost mailbox backup with all internal folder structure like as inbox, calendar, notes, etc. It support almost all versions of MS Outlook and Windows platform.
You can find one of the best as eSoftTools OST Recovery Software in a smart way, easy to search and recover after recovery you can easy to convert OST to PST file with complete data of MS Exchange OST.
