Perfect Solution To Recover Access Database
erinosborne
Access Recovery that easily repairs corrupt or damage MS Access both (.MDB or .ACCDB) database file with all objects including tables, queries, forms, macros, reports, etc. It can also restore your permanently deleted data from MS Access database files. One can check its free demo version before buying its full version. In addition, Comes with 24/7 technical support and 30-day cash back guarantee (Offered Free Demo Version Also)...
Read more about this software :- http://www.mannatsoftware.com/stellar-phoenix-access-recovery.html
adambreowns
Advanced OST to PST Converter tool which can easily recover inaccessible Outlook Emails data from MS Outlook mailbox and easily convert them Outlook PST file format within few mouse clicks.It works on corrupted or damaged or corrupted OST file to convert OST to PST file with different choice formats like- EML, MSG and HTML.
The program is compatible with all versions of MS Outlook 2016 (both 32 bit and 64 bit), 2010, 2007, 2003, 2002, 2000, 98 and 97 and 8, 7, Vista, XP, Windows 2000 ( 32bit/ 64bit )
Download:http://www.regainsoftware.com/ost-to-pst-converter.html
Neil Pattrique
The best way to repair Access database is by using Compact and Repair utility. It's a built-in repair tool in MS Access program that can repair Access database. You can also try to import corrupt Access database into a new database. There's one more thing you can use here, JetComp.exe utility. It's a freeware tool provided by Microsoft that can fix corrupt Access database.
Download MS Access Database Recovery Software to repair corrupt Access MDB and ACCDB file formats. Access Recovery Tool performs safe recovery of all damaged Access database files and can be use on both 32-bit and 64-bit windows 10, 8, 7, Vista, 2003, XP, 2000, etc. OS. Software safely recovers data from its MDB and ACCDB file formats with all large OLE, MEMO and BLOB data.
For further details visit: Access Recovery Tool
selvi
Hi
Manual methods are more reliable than the software because you can do it yourself without affecting the original content. Hence being an expert I would recommend you to go with manual tips to recover MS Access Database.
Thanks
fradiannevin
Repair corrupt or inaccessible MS Access database, I would like to refer an excellent third party software, Repair Access database. the software is compatible with both MDB and ACCDB files of MS Access. The software is empowered with dual recovery modes- Standard Mode and Template mode.
For more information about the software, visit- http://www.repairaccessdatabase.com
If you have a corrupt Access database and you want to repair it, you can use the Compact and Repair utility. It's a built-in repair tool in MS Access program that can repair Access database. There's one feature in MS Access program which you can use here, Import. By using this feature, you can import corrupt Access database into a new database file. Also, Microsoft provides you JetComp.exe utility, a freeware tool to fix corrupt Access database. Refer to this article for complete information - Repair Access Database with Compact and Repair Utility
You can't repair Access database manually if corruption is severe. In such a situation, you should use a professional recovery solution. Download the free demo version of Access Database Recovery software to repair Access database and to restore maximum possible data from it. It supports both MDB and ACCDB files created by any MS Access program. By using the demo version, you can check the preview of your data which you can actually recover from the corrupt Access database.
Thanks.
