Promise IDE RAID controller
I was hoping to use a 6-port Promise IDE RAID controller to be able to nuke multiple disks at once. Does the B&N kernel support these controllers?
The controller is an SX6000.
Thanks for such a nice program!
Hrm, doesn't seem like it....
As a followup, I attempted to use the floppy Boot and Nuke 1.0.1 to nuke a single disk on the raid controller. Boot and Nuke failed with non-fatal errors, and saved a troubleshooting file to the disk. The file seems to indicate that it can't find anything to nuke.
I plugged the disk in to the onboard IDE controller and the disk is nuking normally. The Promise SX6000 RAID controller did see the disk in its own built-in BIOS.
Here's the log file, sorry for the length:
dban0004/
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000008000000 (usable)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
128MB LOWMEM available.
On node 0 totalpages: 32768
zone(0): 4096 pages.
zone(1): 28672 pages.
zone(2): 0 pages.
Kernel command line: initrd=initrd.gz root=/dev/ram0 init=/rc quiet nuke="dwipe" BOOT_IMAGE=kernel.bzi
Initializing CPU#0
Detected 400.918 MHz processor.
Console: colour VGA+ 80x25
Calibrating delay loop... 799.53 BogoMIPS
Memory: 126540k/131072k available (1374k kernel code, 4144k reserved, 578k data, 304k init, 0k highmem)
Dentry cache hash table entries: 16384 (order: 5, 131072 bytes)
Inode cache hash table entries: 8192 (order: 4, 65536 bytes)
Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
Buffer-cache hash table entries: 8192 (order: 3, 32768 bytes)
Page-cache hash table entries: 32768 (order: 5, 131072 bytes)
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 512K
CPU: After generic, caps: 0183f9ff 00000000 00000000 00000000
CPU: Common caps: 0183f9ff 00000000 00000000 00000000
CPU: Intel Pentium II (Deschutes) stepping 02
Enabling fast FPU save and restore... done.
Checking 'hlt' instruction... OK.
Checking for popad bug... OK.
POSIX conformance testing by UNIFIX
PCI: PCI BIOS revision 2.10 entry at 0xfb370, last bus=2
PCI: Using configuration type 1
PCI: Probing PCI hardware
Limiting direct PCI/PCI transfers.
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Starting kswapd
devfs: v1.12c (20020818) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled
Uniform Multi-Platform E-IDE driver Revision: 6.31
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX4: IDE controller on PCI bus 00 dev 39
PIIX4: chipset revision 1
PIIX4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xf000-0xf007, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xf008-0xf00f, BIOS settings: hdc:DMA, hdd:DMA
hda: FX54++W, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
RAMDISK driver initialized: 16 RAM disks of 4096K size 512 blocksize
Compaq SMART2 Driver (v 2.4.21)
Compaq CISS Driver (v 2.4.5)
v2.3 : Micro Memory(tm) PCI memory board block driver
SCSI subsystem driver Revision: 1.00
Loading Adaptec I2O RAID: Version 2.4 Build 5
Detecting Adaptec I2O RAID controllers...
Red Hat/Adaptec aacraid driver, Jun 26 2003
scsi: <fdomain> Detection failed (no card)
NCR53c406a: no available ports found
sym53c416.c: Version 1.0.0-ac
Failed initialization of WD-7000 SCSI card!
IBM MCA SCSI: Version 4.0b
IBM MCA SCSI: No Microchannel-bus present --> Aborting.
This machine does not have any IBM MCA-bus
or the MCA-Kernel-support is not enabled!
DC390: 0 adapters found
megaraid: v1.18 (Release Date: Thu Oct 11 15:02:53 EDT 2001)
megaraid: no BIOS enabled.
aec671x_detect:
3ware Storage Controller device driver for Linux v1.02.00.031.
3w-xxxx: No cards with valid units found.
RAMDISK: Compressed image found at block 0
Freeing initrd memory: 153k freed
VFS: Mounted root (cramfs filesystem) readonly.
Mounted devfs on /dev
Freeing unused kernel memory: 304k freed
8] dwipe: notice: Program loaded.
[2003/09/22 12:41:08] dwipe: notice: Opened entropy source '/dev/urandom'.
[2003/09/22 12:41:08] dwipe: error: Storage devices not found.
[2003/10/22 12:41:02] dban: Found floppy drive /dev/floppy/0.
[2003/10/22 12:41:03] dban: Found 0 seed files on the floppy disk.
[2003/10/22 12:41:08] dban: Wipe started.
[2003/10/22 12:41:08] dban: DBAN finished with non-fatal errors. The disks were not properly wiped, or there were verification errors.
Bus 0, device 0, function 0:
Host bridge: Intel Corp. 440BX/ZX/DX - 82443BX/ZX/DX Host bridge (rev 3).
Master Capable. Latency=64.
Prefetchable 32 bit memory at 0xe8000000 [0xebffffff].
Bus 0, device 1, function 0:
PCI bridge: Intel Corp. 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge (rev 3).
Master Capable. Latency=64. Min Gnt=136.
Bus 0, device 7, function 0:
ISA bridge: Intel Corp. 82371AB/EB/MB PIIX4 ISA (rev 2).
Bus 0, device 7, function 1:
IDE interface: Intel Corp. 82371AB/EB/MB PIIX4 IDE (rev 1).
I/O at 0xf000 [0xf00f].
Bus 0, device 7, function 2:
USB Controller: Intel Corp. 82371AB/EB/MB PIIX4 USB (rev 1).
IRQ 11.
I/O at 0xe000 [0xe01f].
Bus 0, device 7, function 3:
Bridge: Intel Corp. 82371AB/EB/MB PIIX4 ACPI (rev 2).
IRQ 9.
Bus 0, device 11, function 0:
PCI bridge: Intel Corp. 80960RM [i960RM Bridge] (rev 2).
Master Capable. Latency=64. Min Gnt=38.
Bus 0, device 11, function 1:
I2O: Intel Corp. 80960RM [i960RM Microprocessor] (rev 2).
IRQ 10.
Prefetchable 32 bit memory at 0xed000000 [0xed3fffff].
Bus 0, device 13, function 0:
Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 16).
IRQ 5.
Master Capable. Latency=64. Min Gnt=32.Max Lat=64.
I/O at 0xe400 [0xe4ff].
Non-prefetchable 32 bit memory at 0xed500000 [0xed5000ff].
Bus 1, device 1, function 0:
VGA compatible controller: S3 Inc. 86c794 [Savage 3D] (rev 1).
Master Capable. Latency=80. Min Gnt=5.Max Lat=255.
Non-prefetchable 32 bit memory at 0xd8000000 [0xdfffffff].
ed: free: shared: buffers: cached:
Mem: 130048000 1687552 128360448 0 176128 397312
Swap: 0 0 0
MemTotal: 127000 kB
MemFree: 125352 kB
MemShared: 0 kB
Buffers: 172 kB
Cached: 392 kB
SwapCached: 0 kB
Active: 364 kB
Inactive: 332 kB
HighTotal: 0 kB
HighFree: 0 kB
LowTotal: 127000 kB
LowFree: 125348 kB
SwapTotal: 0 kB
SwapFree: 0 kB
n0004/proc/ioports
0020-003f : pic1
0040-005f : timer
0060-006f : keyboard
0080-008f : dma page reg
00a0-00bf : pic2
00c0-00df : dma2
00f0-00ff : fpu
01f0-01f7 : ide0
0320-0323 : wd7000
0350-0353 : wd7000
03c0-03df : vga+
03f2-03f5 : floppy
03f6-03f6 : ide0
03f7-03f7 : floppy DIR
0cf8-0cff : PCI conf1
4000-403f : Intel Corp. 82371AB/EB/MB PIIX4 ACPI
5000-501f : Intel Corp. 82371AB/EB/MB PIIX4 ACPI
9000-cfff : PCI Bus #02
d000-dfff : PCI Bus #01
e000-e01f : Intel Corp. 82371AB/EB/MB PIIX4 USB
e400-e4ff : Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+
f000-f00f : Intel Corp. 82371AB/EB/MB PIIX4 IDE
f000-f007 : ide0
f008-f00f : ide1
1201
0009fc00-0009ffff : reserved
000a0000-000bffff : Video RAM area
000c0000-000c7fff : Video ROM
000d0000-000d3fff : Extension ROM
000f0000-000fffff : System ROM
00100000-07ffffff : System RAM
00100000-00257ab5 : Kernel code
00257ab6-002e8483 : Kernel data
d8000000-e7ffffff : PCI Bus #01
d8000000-dfffffff : S3 Inc. 86c794 [Savage 3D]
e8000000-ebffffff : Intel Corp. 440BX/ZX/DX - 82443BX/ZX/DX Host bridge
ed000000-ed3fffff : Intel Corp. 80960RM [i960RM Microprocessor]
ed400000-ed4fffff : PCI Bus #02
ed500000-ed5000ff : Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+
ffff0000-ffffffff : reserved
0000000400
0: 1610 XT-PIC timer
1: 2 XT-PIC keyboard
2: 0 XT-PIC cascade
6: 8 XT-PIC floppy
14: 6 XT-PIC ide0
NMI: 0
ERR: 0
: 0
vendor_id : GenuineIntel
cpu family : 6
model : 5
model name : Pentium II (Deschutes)
stepping : 2
cpu MHz : 400.918
cache size : 512 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 2
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 sep mtrr pge mca cmov pat pse36 mmx fxsr
bogomips : 799.53
de/ide0/oc/ide/ide0/channel
86 80 11 71 05 00 80 02 01 80 01 01 00 40 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
01 f0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
07 a3 00 80 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 30 0f 00 00 00 00 00 00
n0004/proc/ide/ide0/model
dban0004/proc/ide/ide0/hda/
n0004/proc/ide/ide0/hda/identify
0000 0000 2020 2020 2020 2020 2020 2020
2020 2020 2020 2020 0000 0100 0000 5530
314c 2020 2020 4658 3534 2b2b 5720 2020
2020 2020 2020 2020 2020 2020 2020 2020
2020 2020 2020 2020 2020 2020 2020 0000
0000 0f00 0000 0400 0200 0006 0000 0000
0000 0000 0000 0000 0000 0000 0007 0407
0003 0078 0078 0078 0078 0000 0000 0000
0000 0004 0009 0000 0000 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000
0007 0000 0000 0000 0000 0000 0000 0000
an0004/proc/ide/ide0/hda/model
0004/proc/ide/ide0/hda/settingsname value min max mode
current_speed 0 0 69 rw
ide_scsi 0 0 1 rw
init_speed 0 0 69 rw
io_32bit 0 0 3 rw
keepsettings 0 0 1 rw
nice1 0 0 1 rw
number 0 0 3 rw
pio_mode write-only 0 255 w
slow 0 0 1 rw
unmaskirq 0 0 1 rw
using_dma 0 0 1 rw
piix
Intel PIIX4 Ultra 33 Chipset.
--------------- Primary Channel ---------------- Secondary Channel -------------
enabled enabled
--------------- drive0 --------- drive1 -------- drive0 ---------- drive1 ------
DMA enabled: yes yes yes yes
UDMA enabled: no no no no
UDMA enabled: X X X X
UDMA
DMA
PIO
Similar results with 1.0.2
I get similar results with version 1.0.2. I believe this card should use the I2O driver, but it isn't seeing the raid card at all. Here is the log file:
dban0000/ 0040755 0000000 0000000 00000000000 07745502240 010321 5 ustar 0 0 dban0000/dmesg.txt 0100644 0000000 0000000 00000007154 07745502240 012165 0 ustar 0 0 Linux version 2.4.22-dban (dajhorn@stuntcar) (gcc version 3.3.2 20030908 (Debian prerelease)) #1 Wed Sep 24 14:51:10 EDT 2003
zone(2): 0 pages.
Initializing CPU#0
Detected 400.917 MHz processor.
Memory: 126276k/131072k available (1549k kernel code, 4408k reserved, 628k data, 336k init, 0k highmem)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 8192 (order: 3, 32768 bytes)
CPU: L2 cache: 512K
PCI: Probing PCI hardware (bus 00)
Starting kswapd
Compaq SMART2 Driver (v 2.4.25)
HP CISS Driver (v 2.4.47)
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
PIIX4: IDE controller at PCI slot 00:07.1
Red Hat/Adaptec aacraid driver (1.1.2 Sep 24 2003 14:53:18)
megaraid: v1.18f (Release Date: Tue Dec 10 09:54:39 EST 2002)
aec671x_detect:
GDT: Storage RAID Controller Driver. Version: 2.05
GDT: Found 0 PCI Storage RAID Controllers
3ware Storage Controller device driver for Linux v1.02.00.036.
3w-xxxx: No cards found.
Freeing initrd memory: 154k freed
Freeing unused kernel memory: 336k freed
dban0000/dwipe.txt 0100644 0000000 0000000 00000000277 07745502237 012203 0 ustar 0 0 [2003/09/22 13:22:39] dwipe: notice: Program loaded.
[2003/09/22 13:22:39] dwipe: notice: Opened entropy source '/dev/urandom'.
[2003/09/22 13:22:39] dwipe: error: Storage devices not found.
dban0000/dban.txt 0100644 0000000 0000000 00000000563 07745502237 011775 0 ustar 0 0 [2003/10/22 13:22:33] dban: Darik's Boot and Nuke 1.0.2 started.
[2003/10/22 13:22:33] dban: Found floppy drive /dev/floppy/0.
[2003/10/22 13:22:34] dban: Found 0 seed files on the floppy disk.
[2003/10/22 13:22:39] dban: Wipe started.
[2003/10/22 13:22:39] dban: DBAN finished with non-fatal errors. The disks were not properly wiped, or there were verification errors.
dban0000/proc/ 0040755 0000000 0000000 00000000000 07745502240 011264 5 ustar 0 0 dban0000/proc/pci 0100444 0000000 0000000 00000003421 07745502240 011755 0 ustar 0 0 PCI devices found:
IRQ 11.
IRQ 9.
IRQ 10.
IRQ 5.
dban0000/proc/partitions 0100444 0000000 0000000 00000000034 07745502240 013373 0 ustar 0 0 major minor #blocks name
dban0000/proc/meminfo 0100444 0000000 0000000 00000001007 07745502240 012632 0 ustar 0 0 total: used: free: shared: buffers: cached:
Mem: 129810432 1818624 127991808 0 176128 360448
Swap: 0 0 0
MemTotal: 126768 kB
MemFree: 124992 kB
MemShared: 0 kB
Buffers: 172 kB
Cached: 356 kB
SwapCached: 0 kB
Active: 364 kB
Inactive: 296 kB
HighTotal: 0 kB
HighFree: 0 kB
LowTotal: 126768 kB
LowFree: 124988 kB
SwapTotal: 0 kB
SwapFree: 0 kB
dban0000/proc/ioports 0100444 0000000 0000000 00000001145 07745502240 012702 0 ustar 0 0 0000-001f : dma1
0020-003f : pic1
0040-005f : timer
00a0-00bf : pic2
00c0-00df : dma2
00f0-00ff : fpu
0320-0323 : wd7000
0350-0353 : wd7000
03c0-03df : vga+
03f2-03f5 : floppy
f000-f007 : ide0
f008-f00f : ide1
dban0000/proc/iomem 0100444 0000000 0000000 00000001201 07745502240 012302 0 ustar 0 0 00000000-0009fbff : System RAM
00100000-00283590 : Kernel code
00283591-00320603 : Kernel data
dban0000/proc/interrupts 0100444 0000000 0000000 00000000332 07745502240 013417 0 ustar 0 0 CPU0
0: 1535 XT-PIC timer
2: 0 XT-PIC cascade
6: 8 XT-PIC floppy
NMI: 0
ERR: 0
dban0000/proc/cpuinfo 0100444 0000000 0000000 00000000562 07745502240 012650 0 ustar 0 0 processor : 0
cpu family : 6
model : 5
stepping : 2
cpu MHz : 400.917
cache size : 512 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 2
wp : yes
bogomips : 799.53
dban0000/proc/cmdline 0100444 0000000 0000000 00000000123 07745502240 012611 0 ustar 0 0 initrd=initrd.gz root=/dev/ram0 init=/rc quiet nuke="dwipe" BOOT_IMAGE=kernel.bzi
dban0000/proc/scsi/ 0040555 0000000 0000000 00000000000 07745502240 012223 5 ustar 0 0 dban0000/proc/scsi/scsi 0100444 0000000 0000000 00000000027 07745502240 013103 0 ustar 0 0 Attached devices: none
dban0000/proc/ide/ 0040555 0000000 0000000 00000000000 07745502240 012023 5 ustar 0 0 dban0000/proc/ide/drivers 0100444 0000000 0000000 00000000065 07745502240 013422 0 ustar 0 0 ide-disk version 1.17
ide-default version 0.9.newide
dban0000/proc/ide/piix 0100444 0000000 0000000 00000001012 07745502240 012706 0 ustar 0 0
Controller: 0
enabled enabled
UDMA
DMA
PIO
(Thank you for the verbose post. It is a pleasure to get adequate information.)
The I2O framework was removed after the dban-0.4.0 release. This is the first time that anybody has requested it. I'll see whether I can squeeze it back into the next release.
Thanks for your reply
Thanks for the quick response!
Don't worry about it on my account; I have a bunch of hard drives to purge before I donate them, and I was going to use an existing box I had with that crazy controller. But I can just as easily set up three or more seperate 'nuke boxes' with regular on-board IDE and do multiple simultaneous nukes that way.
In fact, that would probably be better, because I won't as easily overwhelm the processor or RAM.
But, again, thanks for such a great software package. I use it all the time.
By the way, if I were able to get my hands on an internal Iomega Zip 100, where would I send that? We're purging all sorts of stuff, and I may have one of those floating around. I'll have to check for old Western Digital drives, too.
Sure, I would be pleased to accept any spare parts or unusual components. If you send me hardware, then it will become part of my regression suite.
You can send hardware donations to:
Darik Horn
10 Hidden Court
Brantford, Ontario
N3R 6P4
CANADA
Also include some kind of note in the package so that I know from where and why I got it.
TIA
The 1.0.3 beta seems to see this particular Promise controller mentioned above, but it skips it for some reason. From the log:
Code:
ide: Skipping Promise PDC20276 attached to I2O RAID controller.
Have you considered using two kernels, a smaller one with the most common drivers, and one for the CDROM which has basically everything enabled? That way you wouldn't have to remove support for one thing to add another.
Not being a programmer, I don't know how hard that would be. :)
Thanks again for such a good piece of software.
I have a dialog with a potential sponsor of a fat DBAN release. This product will be released if we can cut a deal.
