Paul Huntington
A PST file keeps necessary contacts, notes, messages, journals, emails, and events. It is like a nightmare losing a PST file. Therefore, the best alternative is a third-party program. Fortunately, the technical market offers a range of choices. One of the best among them is the PST Split tool. It is an advanced application to operate on your Windows system. The application is able to divide PST files by size, date, and folders. Users can pick any three options to split a PST file to get the desired results. The split process ends in four easy steps. The application needs no deep technical occupancy to divide a PST file.
Let us now look at the steps that should be performed by the users to split their PST files.
• Download this Split PST app from your app
• Install the app
• Select the file you want to access
• Preview the files
• Select the option you want or want to remove or reset the password.
• Finally, click the "process" button.
Read more :- PST Split tool
• Install the app
• Preview the files
