Reboot
Should it b easy to boot into DOS once DBAN has finished? Im just scared that my computer might not start again. It's working fine just now so I presume there shouldent b any problems. As long as it boots into DOS I can go from there. Do ya reckon it'll boot into DOS no problem?
Is there anything that would actaully prevent me booting into DOS? My comp is working perfect just now, so should it b the same after DBAN'S finished?
Test whether you can boot into DOS with a startup floppy.
You can start the computer from the floppy drive or CD-ROM drive independently of anything on the hard disk. If it works before using DBAN, then it will work after too.
