remaining data
nudgel
Greetings
Running vista home
I have just completed erasing some jpg files 7wipes.
I ran a file search & about 60 of them showed up.
A look at their properties showed them in their original folder but with zero data. They are not in the folder
In the search window I clicked on the Show only - picture icon at the top of the page.
Of the 60 8 still showed a preview pic but again properties show nil data.
Right click no longer gives an erase option. I can not delete or cut & paste as supposedly there is no data.
Totally stumped. Hope someone can help
How are you searching? If you are using the Explorer search that uses a cache and it takes time for the erased files to be removed. This is one of the areas where Eraser cannot get rid of your data for you.
