Remote Install of Nuke?
telegix
I don't suppose there is a way to remotely install dariks boot and nuke into several systems on a local lan and then make it run on some preset settings when it boots up. This would be a eaiser way to nuke a bunch of systems rather then run around with floppy disks to each one.. Any ideas?
It is isn't packaged, but it is possible.
You can do Windows 95/98/ME by installing loadlin changing the autoexec.bat file. Windows NT/2000/XP is more work because you need to wedge it in with NTLOADER.
telegix
Any other solutions which could be implemented eaiser?
maybe boot from nic
im not sure, it might be possible to install it on a shared drive and do boot from network. but dahjorn would know better than i would
I know of several organizations that boot DBAN from the network to wipe workstations. I am working on a polished release of it.
The easiest way to get customizations done is to send a job specification to me for quoting.
I currently use a PXE server, boot to it and then select DBAN to wipe the disk. No need for floppy disk or specific boot disks.
