Shoviv Software is a very popular name in the field of EDB to PST Converter[Shoviv EDB to PST converter] which provides good EDB to PST Conversion and it’s embedded with advanced functions like (Message filtering, email address convention, and PST files splitting). Exchange users can easily convert all the mailboxes of EDB files to PST formats with all internal entities like Contacts, task, calendars, appointments, attachment, etc. With this software, users can export .edb files into different formats like Outlook PST, Office 365, Live Exchange Server and also export into EML, MSG, and HTML. The software is supported by all the Windows OS and MS Windows Server and the software is compatible with all the MS Outlook Version and MS Exchange Version (5.0, 2000, 2003, 2007, 2010, 2013 and 2016).
More details, click here:- EDB to PST converter
1122
If your Exchange EDB file gets damaged due to any reason so I suggest you InQuit EDB to PST Converter program. With the help of this utility, you can access lost and permanently deleted data without creating any difficulty. After the conversion process, you can export your data into PST and other file formats such as EML, HTML, MSG, EMLX, vCal, MBOX, vCard. The user migrates Pub1.edb and Priv1.edb into PST without any hassle. It support OS Windows version 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit). You can download its free demo version that allows you to convert 30 emails per folder free of cost.
Read more: InQuit Exchange Recovery Software
While using Enstella EDB to PST Converter does not need an extra effort for converting EDB files to PST formats. Without any EDB file Size limitation Exchange users easily convert EDB files to PST formats including with all EDB files entity (contacts, task, calendars, reminders, alarms, and embedded images) etc. It supports multiple formats PST, EML, MSG and HTML for saving EDB files over client machine. EDB to PST Converter works well in all MS Exchange server versions and Windows versions.
Note- Get benefits of this EDB to PST Converter Software in lowest price at $99.
I suggest you powerful and advanced EDB email conversion software recovering and converting exchange EDB files to PST files. eSoftTools Exchange EDB to PST Converter software can easily convert EDB to PST items including all EDB emails, contacts, task, calendars, reminders, notes, and embedded images etc. The Software works to export EDB to multiple file formats PST, EML, MSG, EMLX and HTML.
The most reliable EDB to PST Converter Tool which is trusted by most of the Exchange server users is SysInspire EDB to PST Converter Software. It can export or convert inaccessible Exchange EDB file in a different accessible format like PST, EML, EMLX, HTML, MSG, and many more file formats. It can recover information from the Exchange server in any type of corruption or error. It can even divide resultant PST into many new PST. It is available for free as well.
Visit Here For More Info:- Best EDB to PST Conversion
