Paul Huntington
PST Files are bit a complicated subject because it contains emails, contacts, calendar and many more. There are different extensions for all PST components. Thus, in conversion or any kind of data practice in the PST folders can cause data corruption. So if you want Split Large PST files without corrupting it, then I will recommend you to for some automatic tools.it is one of the best tools to split PST files into smaller parts with all emails, contacts, notes, tasks, and etc. without any single data loss. There are no file size limitations, you can split large size Outlook PST files without any single data loss.The MS Outlook split solution is for those users who are looking for safe and sound split of oversized PST files. An ANSI PST file can get corrupt if the file size goes above 2 GB.
Follow this link :- Split Outlook PST | Divide Large PST Files - Free Download
