System.NullReferenceException when erasing files
Kreacher
This morning i downloaded the nightly build 6.0.6.1484 to check if a bug reported before is fixed for me (Exception when wiping free disk space). Unfortunately I now experience problems when erasing files. Sometimes (not everytime) I receive an error message stating that Eraser isn't working anymore. I had a look at the event log and found the following entries:
Protokollname: Application
Quelle: Windows Error Reporting
Datum: 07.01.2010 11:50:50
Ereignis-ID: 1001
Aufgabenkategorie:Keine
Ebene: Informationen
Schlüsselwörter:Klassisch
Benutzer: Nicht zutreffend
Computer: PC
Beschreibung:
Fehlerbucket , Typ 0
Ereignisname: CLR20r3
Antwort: Nicht verfügbar
CAB-Datei-ID: 0
Problemsignatur:
P1: eraser.exe
P2: 6.0.6.1484
P3: 4b457ad1
P4: System.Windows.Forms
P5: 2.0.0.0
P6: 4a275ebd
P7: 1521
P8: 138
P9: System.NullReferenceException
P10:
OS is Windows 7 64 bit, .NET FW 3.5 SP 1 installed (according to ASoft .NET Version Detector)
Hope this event log helps.
Yup I've got a debug build out to a tester who's supposed to get the crash so I can analyze; PM me in three days' time if you don't get any response and I'll get a debug build down your way (I'll try to let the other tester have a go at it, I'll give you only if I get no news from the current tester, it's not good to have too many builds of Eraser floating around)
