TGZ to PST Converter
camilia
Here is software that I would like to recommend KDETools TGZ to PST Converter that will help you with an easy and quick conversion of TGZ files to PST.
Some features are:
  • The application directly import Zimbra TGZ mail to Exchange Server and Office 365 account
  • The tool supports Zimbra TGZ mail to Gmail, G Suite, Google Drive and etc.
  • There is no file size Limitation to import oversized TGZ file to PST.
  • The application also supports various types of file formats such as PST, EML, MBOX, NSF, OLM, PDF, EMLX, HTML, and etc.
  • The user can easily split PST file by size (1 GB to 25 GB).
  • Message Filtering Option to filter the data by date range.
Read More: https://www.kdetools.com/blog/how-to-import-tgz-to-pst.html
If you need to move TGZ data files of Zimbra into Outlook PST and need an easy & simple solution without losing any data from the files. Then I will refer you this Zimbra to PST conversion solution article. The option is one of the best for Zimbra TGZ to PST Conversion method. I also used this solution and it provides the multiple techniques and helps to migrate the data with an accurate and hassle-free manner.
The TGZ to PST Converter is capable of converting a single or several TGZ files to Outlook PST format. This is a preeminent GUI-based program that takes a few humble clicks to transfer TGZ files to Outlook PST.
1. First, Unzip the TGZ file; Select & Right Click on the file & click on Extract Files.
2. Now Launch TGZ to PST Converter on your System.
3. Select conversion option: Single Mailbox & Multiple Mailbox.
4. Next, you can select the mailboxes & start the migration process.
Vartika Zimbra TGZ to Outlook PST Converter programming can essentially change over Zimbra documents into Outlook PST design. This gadget will trade email things, for example, - inbox, outbox, sent mail, note, task, draft, and so on It upholds all renditions of MS Outlook including beginning to now 2019 until. You can likewise use here a free demo rendition to import the usefulness of the application.
Know more info- Zimbra to PST Converter | Migrate TGZ to Outlook
You can try GainTools TGZ Converter Tool is the most effective tool for migrating Zimbra TGZ to Outlook PST files and other popular file formats such as EML, EMLX, MSG, HTML, MHTML, VCF, ICS, MBOX, etc. The Zimbra to Outlook PST Migration tool preserves the original folder structure. This application supports batch conversion at once. This app shows a free preview of an email with an attachment. You can easily activate this app in all versions of Windows OS such as 7, 8, and 8.1, XP, 10, 11, and so on.
Visit here:- https://www.gaintools.com/tgz/
TrustVare Zimbra to PST Converter is a unique tool for converting Zimbra TGZ files to PST format, ideal for Outlook users. The software also allows conversion to MBOX, EML, MSG, and multiple formats, and is done with a simple user interface that includes migrating directly to Office 365 and Live Exchange Server, providing them with an even without technical knowledge can access it. The tool ensures that email data and folder structure are the same during the conversion process.
