Useful EDB to PST Converter Tool
SysOZ EDB to PST Converter helps you to export Your EDB file into Live Exchange Server and Office 365. It also supports MS Exchange Server 5.0, 5.5, 2000, 2003, 2007, 2010, 2013 and 2016.It is easy to use and risk free utility which is responsive for repairing or recovering your EDB files and converting them into PST file format with simple steps. It is the latest version which runs on MS Outlook 2000, 2003, 2007, 2010, 2013, and 2016. You can split your large PST file into multiple small PST file.
Read more: SysOZ EDB to PST Converter
alex786
One can make use of Shoviv EDB to PST Converter software to convert EDB to PST, EML, and MSG format. This tool not only converts EDB to PST but also helps to repair corrupted EDB files and restore deleted items. Using this tool, users can also import EDB to Office 365 and Live Exchange server. It has a free trial version and a good technical support team as well.
Know More: www.shoviv.com/convert-edb-to-pst.html
