Western Digital Drives
orangeblue
WD drives come with a software program called Data Lifeguard Tools. One of the tools allows you to boot from floppy and do a low level format, which writes zeroes to the drive. My question is how effective is this? can I just use DBAN? or would using DBAN then the WD tool be better?
garrett01
Administrator
Staff member
DBAN will wipe multiple times. If the utility does this then it will have the same effect.
Garrett
