jaxonthomas
See, I can help you a lot in this matter so that you can easily convert your PST data to EML format. We know that to convert PST data to EML, we need technical knowledge, and one way is to use third-party software. So, I am giving you the best suggestions that will be very useful to you. I am telling you the name of the software through which you can convert your PST data. The name of this converter is “Softaken Outlook PST Converter”. Now you might be thinking that many tools on the internet do this, so why should I only download this tool? I use this tool myself, so I highly recommend it to you. I'm happy because it can convert not only EML but also other files like MBOX, EMLX, PDF, Office 365, etc. It also has more useful features like filtering your unwanted files, dates, etc. It is a very reliable and trustworthy tool; it runs on all types of Windows, and it is quite simple to use. I hope you like it. Also, the problem you are experiencing may not be due to the use of this software.
