Wiping an entire disk drive
does Eraser allow you to erase an entire drive? so if my computer has a single physical drive, subdivided into partitions C: and D: then will Eraser allow me to clean out all files on boot partition C: ? I think EraserD will do this, but if my computer does not have a floppy then it cannot boot to DOS, so can you suggest what to do?
garrett01
Administrator
Staff member
If you want to totally wipe the machine you need to use Dariks Boot and Nuke.
Can you boot from CD-Rom? There is an ISO image for booting from CD available.
Garrett
