There is propably some bug with update...
Previously I had installed 6.0.8 version. I checked if newer version is availaible - it was. I ordered to download it. But after installation process - there was problem, because I couldn't close window of Eraser, because setup program of newer Eraser was opened.
Then I closed Erasor and manually installed newest revision of 6.0.10. Next problem - after checking for newer updates - I receive info, that I have newer version to install. But... this is identicall the same version ! And I cannot install it either, because the same sittuation as in 6.0.8 revision - is it not possible to close Eraser windows during installation and installer during validating is stopping because of open Eraser windows...
So I suppose - this is not problem of my PC.
P.S.
I use Eraser on Windows XP SP3.
P.S.
