I couldn't see quite where to post this, so this spot is my best guess.
I've just set up Windows XP 64-bit, and so I went to download the 64-bit version of Eraser. All looks good until you are almost ready to press for download, when you notice the file is for ia64, which was the Itanium thing, not the same animal as 64.
I think I'll just go with Eraser 32-bit.
(1) I'd really like to more about this.
(2) More important, I think Eraser's would-be patrons running 64-bit would like to be able to quickly and easily find a paragraph under, say, Supported Systems (or whatever) that lets them know right off the top what they should be installing.
Thanks.
Thanks.
