Archive Converter Crashing on Big Files – Any Fix?
If your archive converter crashes when you try to convert big files, it could be because your machine doesn't have enough memory, the archive size isn't supported or the software is out of date. Softaken Archive Converter Software can help fix the problem in these situations because it is made to work with huge archive files without impacting the integrity of the contents. The utility can change many different types of archives and works with big files in a stable environment, which lowers the risk of crashes. For improved performance, make sure your system has enough RAM, close any background apps that aren't needed, and run the most recent version of the software. You can also try the free demo version to see how it handles big archive files before you buy the full version.
