Best PDF Bates Numbering Tool in 2026
Anshu_123
Cigati PDF Bates Numbering Tool is a reliable utility designed to add Bates numbers to PDF documents with accuracy and consistency. The software helps legal professionals, enterprises, and organizations manage large collections of PDF files by applying sequential numbering for easy identification and document tracking. It supports bulk PDF processing without affecting the original formatting, layout, or data integrity. The tool is compatible with all major Windows operating systems and provides a simple interface for both technical and non-technical users.
Major Features of this Tool:
  1. Add Bates Numbers: Apply sequential Bates numbering to single or multiple PDF files easily.
  2. Bulk PDF Processing: Add Bates numbers to multiple PDF documents in one go.
  3. Custom Numbering Format: Customize prefix, suffix, font size, date, and numbering style.
  4. Maintain Document Integrity: Preserves original formatting, structure, and quality of PDF files.
  5. Multiple Position Options: Place Bates numbers at top, bottom, left, or right positions.
  6. Preview Feature: Preview the applied Bates numbering before saving the final PDF.
  7. Wide Compatibility: Supports all major PDF files created from different applications.
  8. User-Friendly Interface: Simple and easy-to-use tool for all categories of users.
The following are the easy steps to use the Cigati PDF Bates Numbering Tool:
Step 1:
Download and install Cigati PDF Bates Numbering Tool.
Step 2: Click "Add Files" or "Add Folder" to upload PDF documents.
Step 3: Configure Bates numbering settings such as prefix, suffix, and position.
Step 4: Preview the changes and click "Generate Bates Number" to start the process.
