I will only suggest eSoftTools Thunderbird to Outlook Converter when we are looking for the Best Thunderbird to PST Converter. It is one of the most reliable and efficient ways to convert numerous Thunderbird files to the PST format. The tool includes a number of advanced capabilities that allow it to convert Thunderbird files to the PST format in a short amount of time.
Simply follow these basic steps: -
The Thunderbird to Outlook Converter is a program that converts Thunderbird files to PST files.
Select Outlook Files/Folder from the drop-down menu, both automatically and manually.
Select the Convert option.
Read More:- Best Thunderbird to PST Converter
