Best Way to Export Lotus Notes to CSV File Format
MS Outlook is the preferred email client for businesses. However, if you have Lotus Notes data files that you need to convert into CSV format. You can then follow this guide. Two methods can be used to export your Lotus Notes database. To export Lotus Notes database to CSV file format, you can first try a manual approach.
The Cigati NSF Converter tool can convert your Lotus Notes database files into CSV format. This is a reliable and safe tool that uses advanced technology.
