Best Way to Export PST from office 365
alex786
In an organisation, users communicate through emails, which clearly means that emails are the most crucial part of an organisation. Hence, it is important to keep them safe. In case a situation occurs where you have to face poor internet supply, slow connectivity, or accidentally delete your data. Then to deal with these circumstances, users need to have a backup to deal with such situations and keep their emails safe. Therefore, users export PST from Office 365 because PST files are protected with passwords users generally opt for PST files to keep backup. You can perform the exporting task either with a manual method or with a third-party application. The manual method is complicated and risky. Thus, users opt for a third-party application.
The ideal third-party tool you can use to smoothly and quickly export PST to Office 365 is the Shoviv Office 365 Backup and Restore Tool, as it maintains the data originality and hierarchy of folders. Along with PST, the software allows taking backup in HTML, MSG, EML, MBOX, and MHT file formats. It provides an option for users to schedule their backup job. Along with the backup task, the Shoviv software allows restoring Office 365 mailboxes.
Download the free trial version to learn more about Shoviv software.
Read More: https://www.shoviv.com/blog/export-office365-mailbox-to-pst/
chanwoges
To efficiently backup Office 365 to Outlook PST files, try using the Softaken Office 365 backup pro application. Without sacrificing any data, you can convert Office 365 mailbox to Outlook PST files. Also, it stores Office 365 files as PST, EMLX, EML, MBOX, or MSG files among other formats. This tool instantly saves all account data. For non-technical users, it is straightforward to use and understand. While Office 365 is backed up to a PST file, the properties and set of data of your emails are kept intact. provides several filter options for efficiency, including user, date, and mailbox filters. This software is compatible with every version of Windows and Outlook till 2021.
How can I create an Outlook PST backup of my Office365 mailbox?
  • Download the application, then install it on your computer.
  • Then, log in with your Office 365 credentials.
  • Choose the precise files or folders you want to convert or backup.
  • Then pick a format from the list of options.
  • Choose a location to save the resulting files.
  • Select the Process Now tab to start the backup process.
