Bug in 6.1.0.2194
wkwood
I have a manual task with a directory entry, C:\Temp. if the directory doesn't exist Eraser 6.1.0.2194 crashes
To reproduce:
1) Create new Manual Task
2) Add
3) Select Files in Folder
4) Select Folder in Settings, e.g., C:\frobozz (must not exist)
5) Optional, click on delete folder if empty
Select OK
Select OK
Now manually run task via right click -> Run Now Bam!
An Unhandled Exception (System.IO.DirectoryNotFoundException) occurred in Eraser.exe [6364]
I'm sure Joel will pick this up, but you can guarantee that the bug will be fixed if you report it in Trac, which Joel uses as his 'to do' list.
Please report beta bugs in the Beta forum in future. (Join the Beta testers group)
