Bug Report: v5.8 Explorer Menu issue
jackjack
I've rencetly upgraded to eraser 5.8 and discovered there is a small bug.
When in Windows Explorer using key short cuts to access the windows "rename" option (alt+f, m) it no longer works as someone decided to use "m" as the short cut key in the "Eraser Secure Remove" option.
This is rather a bad idea to use the same short cut key as a build in windows option
