vames
Yes, MBOX mailbox data can be changed into DOC (Word) format.
You can do this manually by opening the MBOX file in an email client like Mozilla Thunderbird. Once the emails are visible, open an email, copy its content, and paste it into Microsoft Word. Then save the file as a .doc or .docx format. This method works, but it is suitable only for a small number of emails.
If your MBOX file contains many emails, the manual process can become slow and time-consuming because each email must be converted one by one.
For a more efficient solution, you can use an MBOX to PST Converter, which helps handle mailbox data more easily and supports smooth migration and conversion processes while maintaining email structure and formatting.
