Deployment Eraser
lleroy
I tried to deploy Eraser 6.0.7.1893 with Active directory GPO. for this i extract the two .msi files from the .exe file.
If a standard user log on to the station where eraser was deployed, he got this error when eraser lauch:
Erase settings not set
In the settings tab, there is nothing under default file erasure method, default unused space erasure method, randomness data source.
if a user with administrative privilege log on to the station, eraser work normally. default settings is set.
Does eraser need administrative privilege to run ?
how to correct this situation ?
Is this possible to limit or to restrict some feature to some specific user ?
is this possible to allow user to only be able to erase file or disk store on usb stick or usb disk, but to deny the use on internal Disk ?
best regards
Your main issue: viewtopic.php?f=35&t=5473
Eraser's not currently designed for corporate deployment, so there is no way currently to restrict its use. Would you like to tell me what settings/commands should be restricted? This can be part of a future version.
lleroy
Hello Joel, thanks for the response. but it doesn't correspond to my problem.
Does eraser needt administrative rights to be used ?
For the seconfd point:
It could be easier to deploy eraser with a .admx file which can (for example):
- fix all the settings for corporate ( default file erasure method, default unused space erasure method, ...)
- allow or not to use eraser on usb stick or HDD
- allow or not to use eraser on Internal HDD.
- allow or not to use eraser on network HDD.
No. Administrator rights are only needed for unused space erases and erasing files not owned by the current user.
Please file a ticket for this.
