gomesruiusa
Trusted and protected EDB to PST Converter is designed with a user-friendly interface so that any technical or non-technical user can use it with ease. It is very simple to use for everyone. This is an award-winning application in this field. With the assistance of this great utility, you can access your lost and permanently deleted the file in a few minutes without causing alteration. Through the help of this Exchange EDB to PST software the user can convert single as well as multiple files along with emails, inbox, sent the item, draft, delete-items, attachment, calendar, notes, task (To, Cc, Bcc, Date, From, Object and Time). There is no need to install MS Outlook in your system to convert the data from EDB file to Outlook PST file. It backing OS Windows version 95, NT, 98, ME, XP, Vista, 7, 8, and 8.1,10 (32bit & 64bit).It gives several saving formats such as PST, EML, HTML and MSG for restoring the data after the conversion process as per your need. It split your large PST file into several small PST file without causing any size limitation issues. You can migrate selected data which you want to transfer.
Read More: Secure Download EDB to PST Converter & Recovery Tool
