Enabling Cleaning of Paging File
lisse
Am new to using Eraser 5.7.
How secure is the erasing/cleaning of the paging file when this feature is enabled??
Thanks in advance
Curt
When it is enabled everytime you reboot or shutdown your PC it zeros all the bits 1 time in your paging file. So if you keep rebooting then you will keep overwriting it. I don't think you can do a DOD or Gutmann on your paging file (yet!!)
