Eraser 5.7
RRWood
I was referred to you and Eraser 5.7 by Piriform. I have an older computer with an EIDE hard drive and Windows 98 OS installed on it which I want to donate. I have removed all the files from it which I want to keep (e-mail, address book, documents and files I created). If possible, I would like to leave the OS and other programs which could be of use to someone else on it.
Questions: 1. Does Eraser 5.7 remove selected files or does it erase the entire hard drive?
2. I looked at the downloads for Eraser 5.7 and see there are two files:
Eraser57 zip and Eraser 57Setup zip. What is the smaller file for and does it need to be
installed along with the setup file?
Thank you.
I need Eraser 5.7.1 for an old Windows 2000 machine that still works great. I searched the download page and only found links to download v6.0.10
I'd appreciate some help in downloading v5.7.1
