Joel said:
the Eraser code is so convoluted it is getting more complex and irrational
Joel, I have followed your progress with Eraser over the last couple of months or so and it would seem to me that Eraser 5x must have been an absolute mess before you started work. I notice that most of the initial commits on source forge were general tidying up of code.
Just out of interest how bad was Eraser 5x when you started ?
If Eraser 5x is abandoned I understand that Vista users will be vulnerable for a while until V6 is released but this constant trying to fix bad code means time is wasted trying to make 5x do something it simply wasn’t designed to do. I don’t believe Eraser 5x will ever be quite right on Vista, but at least it works ok for XP, win98 etc.
I myself was all for making certain Eraser 5x was completely bug free before starting work on V6 but there comes a time when you have to step back and accept the situation. There are commercially available free space wipers that work ok on Vista so if anyone is in desperate need to wipe their Vista drives then they at least have an option. I agree that security software should be free and V6 will be, but Eraser 5x needs to be put out of its misery. Eraser 5.86 needs to have the first and last 2KB option removed from the scheduler and also the final DLL pass should be removed then 5.86 can be finalised.
Furthermore all previous versions of Eraser need to be removed from download section as we are all aware now of the serious bug (2KB) in the scheduler.
Joel this must be driving you crazy, give yourself a break and let Eraser 5x rest. Your valuable time would be better spent on V6. :wink:
