Re: Eraser 6.0.x autostart
Eraser 6.2 will have an option not to start Eraser with Windows (as Eraser 5 did).
You don't need to use Task Manager. Just right-clicking on the Eraser tray icon and selecting 'Exit Eraser' will do the job. Also, as you have discovered, with recent versions, you can disable the start with Windows (using the run box to start the built in msconfig program saves you the job of downloading and installing another application), and Eraser will still start normally from a program icon or Start menu entry.
