The installer I've included is .NET 3.5 SP1Bithead said:OK. Fresh install of Eraser 6.0.3.847
A couple of issues:
-I tried letting the Eraser install package install .NET, unfortunately it seems that the installer calls for .NET 3.5 (which times out) rather than the more current 3.5 SP1.
You most probably didn't install the Eraser Root Certificate which is what I use to release betas with. Eraser relies on plugins and therefore it checks for valid certificates included inside plugins before allowing it to run by default. The "default" plugin is also a plugin and therefore it needs to have a certificate too. Short of purchasing a commercial certificate which costs somewhere above $100, I've only been able to create a root cert and ask users to install before running Eraser. The instructions are at http://eraser.heidi.ie/trac/wiki/InstallingBetasBithead said:On first launch I received the following error message:
The following settings held invalid values:
Default file erasure method
Default unused space erasure method
Randomness data source
These settings have now been set to naive (sic) defaults.
Please check that the new settings suit your required level of security.
OK. I did not remember seeing where it said SP1 on the installer. Nonetheless it still kept timing out trying to contact the download site.Joel said:The installer I've included is .NET 3.5 SP1
I did not install the cert (I have now). Just out of curiosity do the $29 GoDaddy Standard SSL certs not work for plugin signing? I do not use them for any of the sites my commercial clients host but use them for a lot of firewall and vpn certificates.Joel said:You most probably didn't install the Eraser Root Certificate which is what I use to release betas with. Eraser relies on plugins and therefore it checks for valid certificates included inside plugins before allowing it to run by default. The "default" plugin is also a plugin and therefore it needs to have a certificate too. Short of purchasing a commercial certificate which costs somewhere above $100, I've only been able to create a root cert and ask users to install before running Eraser.
