On my Win7 machine the behavior of Eraser has changed (Eraser 6.0.10.2620) , such that I am unsure erasure has taken place.
Up until recently, to delete a folder and its contents I did the following:
I can get it to work as expected by using "Erase Schedule --> New Task, selecting run immediately and selecting the folder I want to delete. Then the icon starts throbbing, and Eraser task is described as running.
So what has happened? Could this be due to changes in Win7 system settings (is not fixed if I run as admin)? Whatever, it is very misleading to users, and should have a different behavior, I am sure!
- Right click on the folder and select: Eraser --> Erase
- Eraser icon starts to pulse
- If I go to the Eraser Schedule window I see the task as running. The folder I am deleting, though, is still listed in the Explorer view.
- When the task is completed, the folder is gone (erased!)
- Eraser icon doesn't start pulsing
- if I go to the Eraser Schedule window I see the task listed as "Queued for Execution"
- If i look for the folder I attempted to delete, it is gone (no longer listed).
- If I try to run the 'queued for execution" process I get an error saying the file to delete is not found."
