I'm running XP Pro SP2. I don't seem to have the freeze up problem if I erase 1 Word file at a time, however more times than not if I attempt to erase 10 files or more simultaneously Eraser freezes. I typically use 7 pass DoD.
At Eraser freeze, (it stops running), I check my hard disk and free space goes down from 17+GB to less than 7GB. When I attempt to shut down Eraser, it stops but the dialog box remains up and my computer slows almost to a stop. I use Task Manager to shut down the process but the dialog box still remains up. Finally I use Task Manager to shut down My Documents since I can't manually close it while Eraser is hung. Finally the Eraser dialog box is gone.
I check free space and it remains down 10+GB.
I reopen My Document, find the file Eraser froze on and try to erase again. The last time I did this Eraser indicated "estimated minutes" = 58! It is only a 200kb Word file.
I leave the computer and wait the 58 minutes and the file is finally erased. Here is the Eraser log file:
Statistics:
Erased area = 10585 MB
Cluster tips = 0 bytes
Data written = 74095 MB
Write time = 2856.22 s
Write speed = 26564 kB/s
After all this I check free space and my hard disk is back up to 17+GB.
Obviously I can not continue to use Eraser with continual problem. I uninstalled Eraser and reinstalled it to no avail.
I would very much appreciate any help or insight anyone can give here.
Is Eraser designed to only erase 1 file or a small group of files at one time? What is the recommended maximum size of the file or group?
Thanks.
Statistics:
Thanks.
