Dragan Glas
Greetings,
I've been a long-time user of Eraser, but ran into a problem with the newer versions - those with the system tray icon like a nuclear radiation symbol, rather than the older one which looked like a document. Having made several attempts to install the new version of Eraser, I eventually succeeded in doing so using the following simple solution.
Problem
I use Online Armor on my laptop as my firewall which incorporates HIPS features, as do many firewalls, which add extra security against running processes. These usually appear as pop-up warnings presenting the user with various options from which to choose.
Regardless of whether I chose "Remember once", "Remember for any process", "Install Mode" or "Trust this program", the installer hung after extracting the files - nothing actually appeared or happened.
Workaround
If - like me - you have a failed install, you'll need to remove the dross.
1) In Windows Task Manager (CTRL+ALT+DEL),
2) under the "Process" tab,
3) find the file associated with the installer
4) right-click on it and choose "End Process Tree"
Now, you're ready to do a clean install:
1) Disconnect from the internet
2) Shut down your firewall
3) Run the installer
4) When it's finished installing, run the program and setup whatever tasks you wish or just run some manual ones
5) Re-enable your firewall and only then reconnect to the internet.
Explanation
It's possible that firewalls are offering the "Install mode" option slightly late - with the result that the installer has already run into a problem.
I found that I had no problems with the installation - nor, indeed, with running the program - once I'd followed the above steps. I ran a erasure of the Recycle Bin without any errors and am currently running a erasure of unused space on my C: drive (90% completed).
Kindest regards,
James
Problem
Workaround
Explanation
Kindest regards,
James
