Eraser not integrating into windows explorer
dasdzn
I recently installed Eraser and it is not running properly on my vista or XP. When I try to manually erase the recycle bin I get a 'complete with errors' message: "Could not load file or assembly...eraser.util.unlocker, version=6.0.10.
Help, I'd really like to use this tool!
RandySr1
I had the same problem so this is what I did and it worked for me.
I am running Vista 64bit Home Professional.
I went to the Eraser Home page and went to Downloads on the top right hand side of the page.
Then I went to the "6.2" and downloaded the "Eraser 6.1.0.2804 r2804 17/10/12 2:04am 17932"
I uninstalled the other copy of Eraser I had installed and then ran this one I just downloaded.
It installs without all the options the other one did and my problem was solved!
Now I have the right click for the integrating into windows explorer.
I hope this works for you. :mrgreen:
