Eraser not working recycle bin
groucho121
Yes... I have searched the forms 1st.
Not working problems appear to be related to Window$ Vi$ta.
I am running Windows XP professional w/SP-3.
There are 7) options in the recycle bin from 35 pass gutman down to 1-pass Pseudorandom Data.
I have tried them all, and without fail.......They Fail.
Version 5.86.
How does a person correct this please?
The program does, indeed empty the recyle bin: but the reports all state: Failed.
I'm using version 5.82 on my desktop with only 1) option and it seems to do the job it's supposed to.
If I need to be using 5.82 on my piece of D'heLL, I can try that: if I had the URL to download it.
Any suggestions much appreciated.
Thanks in advance.
Could you post the entire log here?
Thank you for the reply, Joel!
I just emptied the C > Windows >Prefetch in Windows XP Home w/SP-3 :Failed -->
using version 5.82 only 1) option in lieu of 6-7) on the later version.
Using either option, standard Empty Recycle Bin (vs) Erase), the Recycle Bin: Erasing appears fruit-less. :roll:
Task completed. Not all data could be erased.
Statistics:
Erased area = 0 bytes
Cluster tips = 0 bytes
Data written = 0 bytes
Write time = 0.00 s
Below, saved as a .txt file, since it couldn't be Copy & Pasted:
Information:
Statistics:
Write time = 0.00 s
Failures:
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc1.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc10.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc11.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc12.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc13.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc2.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc3.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc4.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc5.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc6.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc7.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc8.pf (Access is denied.)
Failed: C:\RECYCLER\S-1-5-21-2025429265-725345543-839522115-1004\Dc9.pf (Access is denied.)
Eraser functions fine if there is a semi-personal/private word doc or text file (pic even), or any file I want to shred, but the "eraser Recycle Bin" feature appers to be fubared.
I like this program: don't take me wrong.
I'd just like to get it running as it should.
Thanks Much for the reply!
I Hope this isn't a defective or out-dated program/programs (or) I have a compatibilty issue, like XP (vs) Vista.
I'll buy Vista when $ervice Pack 5 comes out on a slip-streamed disk.
What next, please? Advice/Suggestions much appreciated! :)
Better version maybe??
