OK, then ignore my runtimes comment.
Are you running your computer in a corporate environment? Do you see the Eraser context menu entry? If you do, do you see anything after clicking on the menu entry? And please only report problems of the latest version. I know you said you tried later versions, but as a general rule, use the latest versions as they will contain fixes.
By the way, have you tried the betas?
