I've been using Eraser for maybe a month, and I like it. I'm using Eraser 5.86.1.
I only need a light overwrite.
I used Eraser earlier set at 7 passes. But I'd like to use it now with few passes.
Via Preferences > Erasing, I opted to Erase with Pseudorandom Data, which only involves 1 pass.
I have since tried several times to run Eraser with only this one pass, but no luck. Eraser is stuck on a 7-pass erase.
I first noticed this when Eraser was telling me that several hours would be needed to do just one small task. I checked, and it was wanting to do 7 passes.
Repeated attempts at re-setting the Preferences hasn't helped.
Can I fix this?
Thanks,
Andy
Can I fix this?
Thanks,
Andy
