System Win 7 x64
Main prog start and also erase a file(s) by explorershell following windows error:
Beschrijving:
Stopped working
Probleemhandtekening:
Gebeurtenisnaam van probleem: CLR20r3
Probleemhandtekening 01: eraser.exe
Probleemhandtekening 02: 6.0.7.1893
Probleemhandtekening 03: 4bbfca0e
Probleemhandtekening 04: mscorlib
Probleemhandtekening 05: 2.0.0.0
Probleemhandtekening 06: 4a27471d
Probleemhandtekening 07: 47a7
Probleemhandtekening 08: 85
Probleemhandtekening 09: System.IO.FileLoadException
Versie van besturingssysteem: 6.1.7600.2.0.0.256.1
Landinstelling-id: 1043
-Prog is installed in shell, but same error if erase a file(s)
-Windows error solutions reports:
Eraser cannot connect to the running instance for erasures
(see above)
-Old erasure version Erasure setup 64.exe works with exceptions:
Every 2 or 3 system working days this erasure version disappears in the shell for erasing marked single or multiple files.
After a new install repair, its back again for the next 2-3 days.
-Remeber the winxp days there where no problems with erasure. I presume current erasure versions are not fit for Win Vista and 7.
And yes, I closed my firewall-virus etc.... before installation and use.
Any advice?
Beschrijving:
Stopped working
(see above)
Any advice?
