ShadowDemon420
How are you all doing... I am using windows vista.. and I am having problems with eraser I have tried everything... well here is my problem I installed Eraser 5.86.1 and heres my story Im not sure if theres another topic about this but please forgive me... I am using this program to delete music.. heres what happens when I try to delete.. an error message comes up and says administrator privliges required.. so what i did is I went to the icon went to properties and I went to the shortcut icon and clicked on the advance and went to run as administrator than i went to compatibility and went to the privlege level and checked the run as the administrator ... as well than I went to security and it was automatically in full control so I went and unchecked the inheritable permissions from this objects parent so the inherit is off.. so than I open the on demand up... and I went to my music folder and it wouldent let me drag the folder to on demand so than since it wouldent let me drag the file i figured to open the explorer through the on demand and i find the folder and the right clicked and went to erase and then i thought it was going to work but right when the progress bar at the bottom reaches 96% it stops and gives me the same pop up that said administrator privliges required except this time it dident say that its the same error though.... than i said well what the hell so i went back to the icon and right clicked and went to properties agian and i went to run this program in compatibility mode for windows xp service pack 2 and i thought that would help so I went to to the on demand and went to the explorer and found the folder tried to delete and it still would not delete.... so my final attempt even though i went to the properties and said run as administrator... I just right clicked and went to run as administrator tried to delete the folder and it still would not work.. so I am pretty much stumped I have been trying to work on this for like 5 days now... what I am trying to say is that could anyone help me out why it just does not want to co-oprate so Im just hoping you guys might give me some insight thank you a bunch if you can help me
